Installing Motorola Slvr L7 Front Panel
  1. Installing Motorola Slvr L7 Front Panel, Front Panel: step 1, image 1 of 1
    • Push down on the black tab located at the top center of the Motorola phone
  2. Installing Motorola Slvr L7 Front Panel: step 2, image 1 of 1
    • Remove the battery by pulling the battery from the top center.
  3. Installing Motorola Slvr L7 Front Panel: step 3, image 1 of 1
    • Remove the four T6 2 mm TX Torx screws
  4. Installing Motorola Slvr L7 Front Panel: step 4, image 1 of 2 Installing Motorola Slvr L7 Front Panel: step 4, image 2 of 2
    • Insert the flat end of a plastic opening tool and pry the metal cover up off the phone.
  5. Installing Motorola Slvr L7 Front Panel: step 5, image 1 of 2 Installing Motorola Slvr L7 Front Panel: step 5, image 2 of 2
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a plastic opening tool.
  6. Installing Motorola Slvr L7 Front Panel: step 6, image 1 of 1
    • Use a plastic opening tool to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
  7. Installing Motorola Slvr L7 Front Panel: step 7, image 1 of 1
    • Use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • The cover is attached by adhesive, so some force may be required.
  8. Installing Motorola Slvr L7 Front Panel: step 8, image 1 of 2 Installing Motorola Slvr L7 Front Panel: step 8, image 2 of 2
    • Insert the flat end of a spudger and pry the frame off the phone.
    • The frame is attached by adhesive, so some force may be required
Jorge Trujillo
520 Reputation
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 2,979
