Motorola Rival Keyboard Replacement
  1. Motorola Rival Keyboard Replacement, Keyboard: step 1, image 1 of 3 Motorola Rival Keyboard Replacement, Keyboard: step 1, image 2 of 3 Motorola Rival Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Push down on the release tab and pull the back cover away from the device, exposing the battery.
    Ask FixBot
  2. Motorola Rival Keyboard Replacement: step 2, image 1 of 2 Motorola Rival Keyboard Replacement: step 2, image 2 of 2
    • Lift the battery from its compartment to remove it.
    Ask FixBot
  3. Motorola Rival Keyboard Replacement: step 3, image 1 of 2 Motorola Rival Keyboard Replacement: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the six screws around the edge of the device.
    Ask FixBot
  4. Motorola Rival Keyboard Replacement: step 4, image 1 of 2 Motorola Rival Keyboard Replacement: step 4, image 2 of 2
    • Insert the iFixit Opening Tool into the seam where the front and back panels meet and work your way around the perimeter to separate the two panels.
    • Once the two panels are separated, set the front panel to the side. You will be working with the back panel to access the keyboard.
    • The motherboard is now exposed on the back panel.
    Ask FixBot
  5. Motorola Rival Keyboard Replacement: step 5, image 1 of 1
    • Use the iFixit Opening Tool to lift the camera button and remove it from its position.
    Ask FixBot
  6. Motorola Rival Keyboard Replacement: step 6, image 1 of 1
    • Use the iFixit Opening Tool to lift the lock/mute button and remove it from its position.
    Ask FixBot
  7. Motorola Rival Keyboard Replacement: step 7, image 1 of 1
    • Use the iFixit Opening Tool to lift the volume buttons and remove them from their position.
    Ask FixBot
  8. Motorola Rival Keyboard Replacement: step 8, image 1 of 2 Motorola Rival Keyboard Replacement: step 8, image 2 of 2
    • Slide the keyboard out.
    • Use a Phillips #00 screwdriver to remove all of the screws.
    Ask FixBot
  9. Motorola Rival Keyboard Replacement: step 9, image 1 of 3 Motorola Rival Keyboard Replacement: step 9, image 2 of 3 Motorola Rival Keyboard Replacement: step 9, image 3 of 3
    • Insert the iFixit Opening Tool under the edges of the motherboard to lift it out of the back panel and expose the keyboard.
    Ask FixBot
  10. Motorola Rival Keyboard Replacement: step 10, image 1 of 1
    • Remove the old keyboard from the frame.
    • Place the new keyboard into the frame and align the buttons into their respective openings.
    Ask FixBot
To reassemble your device, follow these steps in reverse order.
Sekani Paul
231 Reputation
2 Guides authored
UMass Dartmouth, Team 1-8, Bhusal Fall 2015 Member of UMass Dartmouth, Team 1-8, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G8
2 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 469
