Motorola Razr V3m Screen/Camera Replacement
  1. Motorola Razr V3m Screen/Camera Replacement, Battery: step 1, image 1 of 2 Motorola Razr V3m Screen/Camera Replacement, Battery: step 1, image 2 of 2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Screen/Camera Replacement: step 2, image 1 of 2 Motorola Razr V3m Screen/Camera Replacement: step 2, image 2 of 2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: step 3, image 1 of 2 Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: step 3, image 2 of 2
    • Remove the 4 screws on the corners of the inside screen with the T4 screwdriver
    • The phone may have rubber plugs covering the screws of the inside screen. If so, remove the rubber plugs with a thin metal needle.
  4. Motorola Razr V3m Screen/Camera Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to pry the external shell off of the phone.
    • Use care when doing this step because you don’t want the external shell or the pieces inside the phone to break.
  5. Motorola Razr V3m Screen/Camera Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the two side buttons with tweezers.
  6. Motorola Razr V3m Screen/Camera Replacement: step 6, image 1 of 1
    • Use tweezers to remove the circular magnetic ring covering the camera.
  7. Motorola Razr V3m Screen/Camera Replacement: step 7, image 1 of 2 Motorola Razr V3m Screen/Camera Replacement: step 7, image 2 of 2
    • Use a spudger to pry the screen from the inside front part of the phone.
    • You may choose to use tweezers to remove the screen instead.
Daniel Simcock
731 Reputation
6 Guides authored
UMass Dartmouth, Team 3-2, Shastany Fall 2015 Member of UMass Dartmouth, Team 3-2, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G2
4 Members
7 Guides authored
One Comment
where can this part be purchased?
Alex Alexander - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 415
