Introduction
The purpose of this guide is to help you replace your keypad cover.
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
Lift and remove the rear panel away from the V3c.
Gently pull back case out and lay it over to the side.
Now pull up on the cable attaching the back case to the phone body to separate the two parts. Lay the back case aside for now.
Push the metal tabs along the perimeter of the device through towards the keyboard with your fingers.
Gently lift up on the keypad with the plastic opening tool while being careful not to bend the thin metal portion lining the keypad.
