Motorola RIZR Z3 LCD Replacement
  1. Motorola RIZR Z3 LCD Replacement, Battery: step 1, image 1 of 2 Motorola RIZR Z3 LCD Replacement, Battery: step 1, image 2 of 2
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 LCD Replacement: step 2, image 1 of 2 Motorola RIZR Z3 LCD Replacement: step 2, image 2 of 2
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 LCD Replacement, Motherboard: step 3, image 1 of 1
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 LCD Replacement: step 4, image 1 of 2 Motorola RIZR Z3 LCD Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 LCD Replacement: step 5, image 1 of 1
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 LCD Replacement: step 6, image 1 of 2 Motorola RIZR Z3 LCD Replacement: step 6, image 2 of 2
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 LCD Replacement: step 7, image 1 of 2 Motorola RIZR Z3 LCD Replacement: step 7, image 2 of 2
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 LCD Replacement: step 8, image 1 of 2 Motorola RIZR Z3 LCD Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
  9. Motorola RIZR Z3 LCD Replacement, LCD: step 9, image 1 of 1
    • Turn the phone to the front.
    • Push the keypad out through the plastic casing.
  10. Motorola RIZR Z3 LCD Replacement: step 10, image 1 of 1
    • Turn the phone to the side.
    • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
  11. Motorola RIZR Z3 LCD Replacement: step 11, image 1 of 1
    • Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
  12. Motorola RIZR Z3 LCD Replacement: step 12, image 1 of 3 Motorola RIZR Z3 LCD Replacement: step 12, image 2 of 3 Motorola RIZR Z3 LCD Replacement: step 12, image 3 of 3
    • Use a spudger to pry the plastic screen casing partially up from the LCD unit.
    • Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
    • Caution: Do this carefully, damage to this ribbon cable will cause a blank screen.
    • Pull the plastic screen casing directly away from the LCD unit.
  13. Motorola RIZR Z3 LCD Replacement: step 13, image 1 of 2 Motorola RIZR Z3 LCD Replacement: step 13, image 2 of 2
    • Use a spudger to lift the LCD partially away from the metal casing.
    • Use the spudger to pry the ribbon cable directly up from its clip on the metal casing.
    • Caution: Damage to the ribbon cable here will cause screen damage.
    • Pull the LCD completely away from the metal casing.
Brooke Shuford
65 Reputation
3 Guides authored
Cal Poly, Team 5-34, Amido Fall 2011 Member of Cal Poly, Team 5-34, Amido Fall 2011
CPSU-AMIDO-F11S5G34
4 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 16
All Time: 968
