Motorola Photon 4G MB855 Headphone Jack Replacement
  1. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Back Cover: step 1, image 1 of 2 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Back Cover: step 1, image 2 of 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Battery: step 2, image 1 of 2 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Battery: step 2, image 2 of 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: step 3, image 1 of 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: step 3, image 2 of 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: step 4, image 1 of 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: step 4, image 2 of 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: step 4, image 3 of 3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Headphone Jack Replacement, Locating Headphone Jack: step 5, image 1 of 1
    • Locate Headphone Jack attached to Midframe.
  6. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: step 6, image 1 of 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: step 6, image 2 of 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: step 6, image 3 of 3
    Buy
    • Use Tweezers to gently remove Headphone Jack from the Midframe.
    • The Headphone Jack is attached with adhesive, remove carefully.
Eddie Krause
260 Reputation
3 Guides authored
USF Tampa, Team 8-6, Leahy Fall 2014 Member of USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 326
