Motorola Moto Z Force Droid Digitizer Replacement
  1. Motorola Moto Z Force Droid Digitizer Replacement, LCD Screen and Digitizer Assembly: step 1, image 1 of 1
    • Only the LCD screen and digitizer assembly remains.
    • Check carefully to make sure your replacement part matches, and that you've removed all the necessary parts from the old frame for installation in the new one.
  2. Motorola Moto Z Force Droid Digitizer Replacement, Digitizer: step 2, image 1 of 3 Motorola Moto Z Force Droid Digitizer Replacement, Digitizer: step 2, image 2 of 3 Motorola Moto Z Force Droid Digitizer Replacement, Digitizer: step 2, image 3 of 3
    • Take the front assembly.
    • Remove the copper tape with a pair of tweezers.
  3. Motorola Moto Z Force Droid Digitizer Replacement: step 3, image 1 of 3 Motorola Moto Z Force Droid Digitizer Replacement: step 3, image 2 of 3 Motorola Moto Z Force Droid Digitizer Replacement: step 3, image 3 of 3
    • Lift the digitizer wiring with a pair of tweezers but do not pull out the wiring.
    • Do not use a heat gun to remove the tape.
  4. Motorola Moto Z Force Droid Digitizer Replacement: step 4, image 1 of 1
    • Begin to separate the front screen from the metal plate with the plastic opening tool.
  5. Motorola Moto Z Force Droid Digitizer Replacement: step 5, image 1 of 2 Motorola Moto Z Force Droid Digitizer Replacement: step 5, image 2 of 2
    • Carefully fold the digitizer such that it ends up in the middle of the wiring plate.
    • Gently pull the metal plate off of the digitizer in a slight counterclockwise manner as to not damage the wiring plate.
Kenji Fong
1,606 Reputation
4 Guides authored
Cal Poly, Team S1-G1, Livingston Winter 2018 Member of Cal Poly, Team S1-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G1
4 Members
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 3,114
