Repairing Motorola Moto Q Back Casing
  1. Repairing Motorola Moto Q Back Casing, Back Casing: step 1, image 1 of 1
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Repairing Motorola Moto Q Back Casing: step 2, image 1 of 1
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Repairing Motorola Moto Q Back Casing: step 3, image 1 of 2 Repairing Motorola Moto Q Back Casing: step 3, image 2 of 2
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Repairing Motorola Moto Q Back Casing: step 4, image 1 of 2 Repairing Motorola Moto Q Back Casing: step 4, image 2 of 2
    • Gently lift and remove the back casing.
Luis Herrera
52 Reputation
4 Guides authored
Cal Poly, Team 16-33, Maness Winter 2010 Member of Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 5,156
