Motorola Moto G6 LCD Assembly Replacement
  1. Motorola Moto G6 LCD Assembly Replacement, Remove Back Glass: step 1, image 1 of 1
    • The glass backplate needs to be removed first.
    • Heat along left edge of the backplate until the glass is almost too hot to touch.
  2. Motorola Moto G6 LCD Assembly Replacement, Remove Backplate: step 2, image 1 of 3 Motorola Moto G6 LCD Assembly Replacement, Remove Backplate: step 2, image 2 of 3 Motorola Moto G6 LCD Assembly Replacement, Remove Backplate: step 2, image 3 of 3
    • Carefully insert razor blade in between glass back plate and frame of phone.
    • Do not insert blade any farther than a few millimeters! Be careful not to scratch frame or glass with the blade.
    • With glass lifted slightly, you can now insert a regular opening pick and remove the razor blade.
    • Note that the glass is curved and you will need to insert the pick at an angle when you push it in further.
  3. Motorola Moto G6 LCD Assembly Replacement, Remove Backplate: step 3, image 1 of 3 Motorola Moto G6 LCD Assembly Replacement, Remove Backplate: step 3, image 2 of 3 Motorola Moto G6 LCD Assembly Replacement, Remove Backplate: step 3, image 3 of 3
    • Work pick in further to slowly lift the glass away from the frame.
    • Slide pick to bottom of phone and insert a new pick on the left side
    • Slide pick along left edge towards the top of the phone.
    • If there is too much resistance from the adhesive, reheat the glass before continuing.
  4. Motorola Moto G6 LCD Assembly Replacement, Removing Backplate: step 4, image 1 of 3 Motorola Moto G6 LCD Assembly Replacement, Removing Backplate: step 4, image 2 of 3 Motorola Moto G6 LCD Assembly Replacement, Removing Backplate: step 4, image 3 of 3
    • Continue around right side of the backplate using the same procedure as Step 3 until the adhesive has been cut around the entire glass backplate.
    • Carefully remove backplate. It should come off fairly easily. If there is any resistance, heat that area and cut the adhesive again with opening pick.
  5. Motorola Moto G6 LCD Assembly Replacement, Remove frame: step 5, image 1 of 1
    • Remove ten 3.2mm silver Phillips #000 screws
    • Remove one 3.8mm silver Phillips #000 screw
    • Remove five 2.7mm black phillips #000 screws
  6. Motorola Moto G6 LCD Assembly Replacement: step 6, image 1 of 3 Motorola Moto G6 LCD Assembly Replacement: step 6, image 2 of 3 Motorola Moto G6 LCD Assembly Replacement: step 6, image 3 of 3
    • Carefully peel up black tape from battery to reveal one last screw.
    • Do not completely remove black tape. You only need to pull back so that the tape is not attached to the battery or covering the screw.
  7. Motorola Moto G6 LCD Assembly Replacement: step 7, image 1 of 1
    • Remove final 3.2mm silver Phillips #000 screw.
  8. Motorola Moto G6 LCD Assembly Replacement: step 8, image 1 of 3 Motorola Moto G6 LCD Assembly Replacement: step 8, image 2 of 3 Motorola Moto G6 LCD Assembly Replacement: step 8, image 3 of 3
    • Remove plastic plate covering the motherboard. You may need to start it using fingernails or a spudger.
    • It is all one piece, be careful not to bend or crack it.
  9. Motorola Moto G6 LCD Assembly Replacement, Disconnect the Battery: step 9, image 1 of 2 Motorola Moto G6 LCD Assembly Replacement, Disconnect the Battery: step 9, image 2 of 2
    • Using a plastic nylon spudger, carefully pry up on the battery connector to disconnect the battery.
  10. Motorola Moto G6 LCD Assembly Replacement: step 10, image 1 of 1
    • remove two 2.8mm black phillips000 screws.
  11. Motorola Moto G6 LCD Assembly Replacement: step 11, image 1 of 3 Motorola Moto G6 LCD Assembly Replacement: step 11, image 2 of 3 Motorola Moto G6 LCD Assembly Replacement: step 11, image 3 of 3
    • Using a plastic spudger or prying tool, carefully lift the snap connectors attached to the Motherboard.
    • Lift the black antenna cable out from next to the vibrator motor so that it is loose from the frame.
    • Using a spudger, carefully lift the black lever of the zif connector (indicated by the arrow), then using tweezers, carefully pull the flex cable out of the connector.
  12. Motorola Moto G6 LCD Assembly Replacement, Remove the Motherboard: step 12, image 1 of 3 Motorola Moto G6 LCD Assembly Replacement, Remove the Motherboard: step 12, image 2 of 3 Motorola Moto G6 LCD Assembly Replacement, Remove the Motherboard: step 12, image 3 of 3
    • Don't forget to eject the sim card tray like I almost did.
    • Carefully lift the motherboard out of the frame.
    • Once the upper part is free, pull the motherboard upwards and out, so that the charging port does not get stuck on the frame.
  13. Motorola Moto G6 LCD Assembly Replacement, Option 1: step 13, image 1 of 3 Motorola Moto G6 LCD Assembly Replacement, Option 1: step 13, image 2 of 3 Motorola Moto G6 LCD Assembly Replacement, Option 1: step 13, image 3 of 3
    • From this point, you can remove the battery and move what is needed to a new screen and frame assembly.
  14. Motorola Moto G6 LCD Assembly Replacement, Option 2: step 14, image 1 of 2 Motorola Moto G6 LCD Assembly Replacement, Option 2: step 14, image 2 of 2
    • Or you can keep the battery in and only remove the LCD and digitizer from the frame.
    • This may be easier and cheaper than trying to swap the battery, but you will have to clean off the old adhesive and apply your own adhesive to hold down the new screen.
    • Be careful of the home button cable if removing the LCD and Digitizer
    • I forgot to take a picture of this step and the picture shown is of a Galaxy J3 without its LCD assembly. I will upload another if I come across another Moto G6. Please upload your own if you do this step.
Reed Deemer
1,261 Reputation
1 Guide authored
Past 24 Hours: 14
Past 7 Days: 36
Past 30 Days: 156
All Time: 27,302
