Motorola Moto G4 Play USB port Replacement
  1. Motorola Moto G4 Play USB port Replacement, Remove back cover and battery: step 1, image 1 of 2 Motorola Moto G4 Play USB port Replacement, Remove back cover and battery: step 1, image 2 of 2
    • pull back plate off starting with this tab
  2. Motorola Moto G4 Play USB port Replacement, remove 16 screws: step 2, image 1 of 3 Motorola Moto G4 Play USB port Replacement, remove 16 screws: step 2, image 2 of 3 Motorola Moto G4 Play USB port Replacement, remove 16 screws: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • remove 16 00 philips screws
    • pull up sticker with tweezers to reveal the last screw
    • no screw here
    • remove battery sd card, and sim card
  3. Motorola Moto G4 Play USB port Replacement, remove USB board: step 3, image 1 of 3 Motorola Moto G4 Play USB port Replacement, remove USB board: step 3, image 2 of 3 Motorola Moto G4 Play USB port Replacement, remove USB board: step 3, image 3 of 3
    • disconnect antenna with spudger
    • disconnect data cable with spudger
    • Remove 2 00 philips screws
    • carefully remove USB board and vibrator together
    • disconnect vibrator from board with spudger.
    • Pull the rubber support gasket off of the old usb port.
Michael Cottone
957 Reputation
2 Guides authored
Cottone Computing Member of Cottone Computing
Business
1 Member
2 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,579
