Introduction
Use this guide to replace the motherboard on your Motorola Moto E.
To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
Gently pull up on the red and black power cable to lift the connector out of the motherboard.
Move the battery and cover away from the motherboard.
