Motorola MC5590 LCD Screen Replacement
    1. Motorola MC5590 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Push in the battery release button.
      Ask FixBot
    2. Motorola MC5590 LCD Screen Replacement: step 2, image 1 of 1
      • Pull out battery.
      Ask FixBot
    1. Motorola MC5590 LCD Screen Replacement, Keyboard: step 3, image 1 of 2 Motorola MC5590 LCD Screen Replacement, Keyboard: step 3, image 2 of 2
      • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
      Ask FixBot
    2. Motorola MC5590 LCD Screen Replacement: step 4, image 1 of 3 Motorola MC5590 LCD Screen Replacement: step 4, image 2 of 3 Motorola MC5590 LCD Screen Replacement: step 4, image 3 of 3
      • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
      Ask FixBot
    3. Motorola MC5590 LCD Screen Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
      Ask FixBot
    4. Motorola MC5590 LCD Screen Replacement: step 6, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 6, image 2 of 2
      • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
      Ask FixBot
    5. Motorola MC5590 LCD Screen Replacement: step 7, image 1 of 1
      • Remove the keyboard cover.
      Ask FixBot
    6. Motorola MC5590 LCD Screen Replacement: step 8, image 1 of 3 Motorola MC5590 LCD Screen Replacement: step 8, image 2 of 3 Motorola MC5590 LCD Screen Replacement: step 8, image 3 of 3
      • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
      • Pull the ribbon cable out of the socket.
      Ask FixBot
    7. Motorola MC5590 LCD Screen Replacement: step 9, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 9, image 2 of 2
      • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
      • Remove the keyboard from the device.
      Ask FixBot
    1. Motorola MC5590 LCD Screen Replacement, Speaker: step 10, image 1 of 2 Motorola MC5590 LCD Screen Replacement, Speaker: step 10, image 2 of 2
      • Pull the black rubber tabs up gently and remove them.
      Ask FixBot
    2. Motorola MC5590 LCD Screen Replacement: step 11, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 11, image 2 of 2
      • Using your finger, or spudger, push the motherboard out from the bottom.
      Ask FixBot
    3. Motorola MC5590 LCD Screen Replacement: step 12, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 12, image 2 of 2
      • Remove the three Phillips #00 screws from the motherboard:
      • Two 3mm screws.
      • One 1mm screw.
      Ask FixBot
    4. Motorola MC5590 LCD Screen Replacement: step 13, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 13, image 2 of 2
      • Disconnect the speaker from the motherboard.
      Ask FixBot
    1. Motorola MC5590 LCD Screen Replacement, LCD Screen: step 14, image 1 of 3 Motorola MC5590 LCD Screen Replacement, LCD Screen: step 14, image 2 of 3 Motorola MC5590 LCD Screen Replacement, LCD Screen: step 14, image 3 of 3
      • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
      • Remove the antenna.
      • Remove the flex cable cover.
      Ask FixBot
    2. Motorola MC5590 LCD Screen Replacement: step 15, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 15, image 2 of 2
      • Remove the five 3mm Phillips #00 screws from the motherboard.
      Ask FixBot
    3. Motorola MC5590 LCD Screen Replacement: step 16, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 16, image 2 of 2
      • Remove the scanner ribbon cable by pulling straight up and out.
      Ask FixBot
    4. Motorola MC5590 LCD Screen Replacement: step 17, image 1 of 2 Motorola MC5590 LCD Screen Replacement: step 17, image 2 of 2
      • Flip open the motherboard and the LCD screen.
      • Open the LCD connector and remove the cable.
      • Pull the LCD Screen and its metal bracket apart.
      Ask FixBot
Tyler Jean
555 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Cagle Spring 2018 Member of USF Tampa, Team S1-G6, Cagle Spring 2018
USFT-CAGLE-S18S1G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 55
All Time: 1,163
