Repairing Motorola Krzr K1m LCD
  1. Repairing Motorola Krzr K1m LCD, LCD: step 1, image 1 of 2 Repairing Motorola Krzr K1m LCD, LCD: step 1, image 2 of 2
    Tool used on this step:
    Spudger
    $3.99
    Buy
    • Begin by removing the trim piece from around the front face plate.
    • Be very careful when dealing with the trim. It is very delicate, so be cautious when approching this next part.
    • Using your fingers or The Spudger get underneath the trim. Start by applying enough force to pry the trim off.
    • Be patient when trying to pry off the trim. The tape attaching the trim to the phone is very strong. Just be persistent and patient and it will eventually give.
    • Remove the trim piece.
  2. Repairing Motorola Krzr K1m LCD: step 2, image 1 of 2 Repairing Motorola Krzr K1m LCD: step 2, image 2 of 2
    • Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws.
  3. Repairing Motorola Krzr K1m LCD: step 3, image 1 of 2 Repairing Motorola Krzr K1m LCD: step 3, image 2 of 2
    Spudger
    $3.99
    Buy
    • Gently use The Spudger towards the edge of the phone and lift the face plate off.
    • The touch-sensitive keys and chip board/LCD screen (which is green) may remain attached to the face plate because of the glue.
    • Gently hold the green logic board down as you lift the face plate apart from it.
    • Remove the face plate.
  4. Repairing Motorola Krzr K1m LCD: step 4, image 1 of 3 Repairing Motorola Krzr K1m LCD: step 4, image 2 of 3 Repairing Motorola Krzr K1m LCD: step 4, image 3 of 3
    • Gently, with your fingers or a tweezer, lift the orange flex cable apart from the pin connector it is connected to.
    • Gently remove the green logic board/LCD (Liquid Crystal Display) screen away from the phone.
    • Replace with new green logic board/LCD screen.
    • To reassemble the phone, follow of the steps in reverse order.
Jennifer Hudiono
42 Reputation
4 Guides authored
Cal Poly, Team 11-1, Forte Winter 2010 Member of Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
5 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 6,563
