Motorola Edge (2021) Camera module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
86
All Time:
644
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide demonstrates how to properly remove the camera module attached to the motherboard casing in the back of your Motorola Edge (2021) phone. This module is responsible for protecting the camera like a case. This replacement may be needed if the phone falls and happens to crack the camera module.
Tools
    1. Motorola Edge (2021) Camera module Replacement, Camera: step 1, image 1 of 1
      • Use the iFixit iOpeners to heat the back of the phone by placing them vertically along the sides. This will weaken the glue so it opens easier.
      Ask FixBot
    2. Motorola Edge (2021) Camera module Replacement: step 2, image 1 of 2 Motorola Edge (2021) Camera module Replacement: step 2, image 2 of 2
      • After the heating process, use the iFixit opening pick to slide in between the cracks, separating the glue.
      Ask FixBot
    3. Motorola Edge (2021) Camera module Replacement: step 3, image 1 of 1
      • Gently remove the back panel of the smartphone.
      Ask FixBot
    4. Motorola Edge (2021) Camera module Replacement: step 4, image 1 of 2 Motorola Edge (2021) Camera module Replacement: step 4, image 2 of 2
      • Now you need to uncrews the camera/motherboard casing.
      • Unscrew all the screws under the circles. Be careful not to miss a screw that might be hiding under the glue.
      Ask FixBot
    5. Motorola Edge (2021) Camera module Replacement: step 5, image 1 of 2 Motorola Edge (2021) Camera module Replacement: step 5, image 2 of 2
      • Use the iFixit prying tool to gently slide the camera casing off the phone. Be careful not to damage the motherboard underneath.
      Ask FixBot
Jaier
339 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 86
All Time: 644
