Installing Motorola E815 Keypad
  1. Installing Motorola E815 Keypad, Battery: step 1, image 1 of 1
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Installing Motorola E815 Keypad: step 2, image 1 of 1
    • Remove the back cover by pulling it away from the phone.
  3. Installing Motorola E815 Keypad: step 3, image 1 of 2 Installing Motorola E815 Keypad: step 3, image 2 of 2
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Installing Motorola E815 Keypad, Disassembling Motorola E815 Antenna: step 4, image 1 of 1
    • Locate the antenna port on the top of the phone.
  5. Installing Motorola E815 Keypad: step 5, image 1 of 2 Installing Motorola E815 Keypad: step 5, image 2 of 2
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Installing Motorola E815 Keypad, Keypad: step 6, image 1 of 1
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using a T6 Screwdriver.
  7. Installing Motorola E815 Keypad: step 7, image 1 of 3 Installing Motorola E815 Keypad: step 7, image 2 of 3 Installing Motorola E815 Keypad: step 7, image 3 of 3
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Carefully detach the two sections of the phone.
  8. Installing Motorola E815 Keypad: step 8, image 1 of 3 Installing Motorola E815 Keypad: step 8, image 2 of 3 Installing Motorola E815 Keypad: step 8, image 3 of 3
    • Using the blue pry tool, carefully pull the keypad frame away from the keypad.
    • Gently remove the keypad frame from the keypad.
    • Lift the silicone keypad cover off.
  9. Installing Motorola E815 Keypad: step 9, image 1 of 2 Installing Motorola E815 Keypad: step 9, image 2 of 2
    • Rotate the phone around so that you are looking at the battery cavity.
    • Locate the screws on the bottom base of the phone.
  10. Installing Motorola E815 Keypad: step 10, image 1 of 2 Installing Motorola E815 Keypad: step 10, image 2 of 2
    • Rotate the phone back to the front side.
    • Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
  11. Installing Motorola E815 Keypad: step 11, image 1 of 3 Installing Motorola E815 Keypad: step 11, image 2 of 3 Installing Motorola E815 Keypad: step 11, image 3 of 3
    • Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
    • Separate the keypad from the circuit board.
Zoie E
603 Reputation
5 Guides authored
Cal Poly, Team 14-8, Forte Winter 2011 Member of Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,099
