Motorola E815 Front Screen Replacement
  1. Motorola E815 Front Screen Replacement, Battery: step 1, image 1 of 1
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Motorola E815 Front Screen Replacement: step 2, image 1 of 1
    • Remove the back cover by pulling it away from the phone.
  3. Motorola E815 Front Screen Replacement: step 3, image 1 of 2 Motorola E815 Front Screen Replacement: step 3, image 2 of 2
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Motorola E815 Front Screen Replacement, Disassembling Motorola E815 Antenna: step 4, image 1 of 1
    • Locate the antenna port on the top of the phone.
  5. Motorola E815 Front Screen Replacement: step 5, image 1 of 2 Motorola E815 Front Screen Replacement: step 5, image 2 of 2
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Motorola E815 Front Screen Replacement, Front Screen: step 6, image 1 of 3 Motorola E815 Front Screen Replacement, Front Screen: step 6, image 2 of 3 Motorola E815 Front Screen Replacement, Front Screen: step 6, image 3 of 3
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using your T6 screwdriver.
  7. Motorola E815 Front Screen Replacement: step 7, image 1 of 3 Motorola E815 Front Screen Replacement: step 7, image 2 of 3 Motorola E815 Front Screen Replacement: step 7, image 3 of 3
    • Grasp the top of the phone near the speaker.
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Detach the top section of the phone from the keypad section.
  8. Motorola E815 Front Screen Replacement: step 8, image 1 of 2 Motorola E815 Front Screen Replacement: step 8, image 2 of 2
    • Carefully insert the blue pry tool into the notch between the two halves of the top section of the phone.
    • Gently pry the two halves apart.
  9. Motorola E815 Front Screen Replacement: step 9, image 1 of 1
    • Rotate the top section of the phone around so that you are looking at the outer screen.
    • Disconnect the cover from the outer screen side of the phone.
  10. Motorola E815 Front Screen Replacement: step 10, image 1 of 3 Motorola E815 Front Screen Replacement: step 10, image 2 of 3 Motorola E815 Front Screen Replacement: step 10, image 3 of 3
    • Rotate the top section of the phone around so you are looking at the large screen.
    • Using your fingers, lift the protector off of the screen.
  11. Motorola E815 Front Screen Replacement: step 11, image 1 of 1
    • Using the blue pry tool, gently remove the screen cover.
    • Since it is glued into place, it may take some maneuvering to remove.
  12. Motorola E815 Front Screen Replacement: step 12, image 1 of 3 Motorola E815 Front Screen Replacement: step 12, image 2 of 3 Motorola E815 Front Screen Replacement: step 12, image 3 of 3
    • Turn the phone so that you can see the side metal clasps.
    • Using the blue lifter tool, snap the metal clasps off of screen body.
    • Proceed to snap all four corners of the metal cover off of the screen body.
  13. Motorola E815 Front Screen Replacement: step 13, image 1 of 2 Motorola E815 Front Screen Replacement: step 13, image 2 of 2
    • Using tweezers, gently detach the brown connecting strip from the back of the screen.
    • Separate the screen from the phone frame.
    • The front screen can now be accessed and replaced!
Zoie E
603 Reputation
5 Guides authored
Cal Poly, Team 14-8, Forte Winter 2011 Member of Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,319
