Introduction
You've tried to turn your phone off for work, but the power button is stuck. Fortunately, with this guide, you can fix this problem and have control over your phone's life again.
Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
Use tweezers to lift the black bar on top of the ZIF connector.
Pull the ribbon cable out of the connector with tweezers.
Now that there are no cables connecting the screen to the motherboard, remove the screen.
Use a plastic opening tool to lift up the rear camera.
Use tweezers to lift and unlock the black bar on top of the rear camera's ZIF connector.
Pull the camera out of the connector.
Using a plastic opening tool or tweezers, disconnect the power button connector.
Carefully peel back the adhesive cable with the tweezers so it is not in the way of the motherboard.
Disconnect the battery from the motherboard by lifting up with the plastic opening tool near the base of the cable.
Bend the battery cable straight up and out of the way of the motherboard.
Using tweezers, peel back the adhesive covering the speaker connector.
Using tweezers, disconnect the speaker connector by lifting underneath the base of the connector.
Locate the sim card/micro sd tray on the side of the device.
Push a small rod, such as a paper clip or sim card tool, into the opening to eject and remove the tray.
Remove the six 3.5mm Torx T4 screws securing the motherboard to the device frame.
Carefully pry up the motherboard from the frame using a plastic opening tool.
Use a plastic opening tool to lift up the battery from the frame of the device.
Remove the battery.
Remove the three 3.5mm Torx T3 screws holding the power/volume button cable to the side of the frame.
Using tweezers, remove the power/volume button flex cable.
Remove the flex cable from the metal bracket using a plastic opening tool.
