Introduction
Use this guide to replace the entire front panel assembly on your Motorola Droid RAZR HD. This includes the
Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
Use tweezers to remove the yellow tape covering the lcd/digitizer cable connector.
Carefully tilt up the black lever to release the lcd/digitizer cable. Caution! If the lever pops out there is trouble ahead.
Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
Use tweezers to lift the black bar on top of the ZIF connector.
Pull the ribbon cable out of the connector with tweezers.
Now that there are no cables connecting the screen to the motherboard, remove the screen.
