Installing Motorola Droid RAZR Camera Cover
  1. Installing Motorola Droid RAZR Camera Cover, Back Cover: step 1, image 1 of 2 Installing Motorola Droid RAZR Camera Cover, Back Cover: step 1, image 2 of 2
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Installing Motorola Droid RAZR Camera Cover: step 2, image 1 of 3 Installing Motorola Droid RAZR Camera Cover: step 2, image 2 of 3 Installing Motorola Droid RAZR Camera Cover: step 2, image 3 of 3
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Installing Motorola Droid RAZR Camera Cover: step 3, image 1 of 3 Installing Motorola Droid RAZR Camera Cover: step 3, image 2 of 3 Installing Motorola Droid RAZR Camera Cover: step 3, image 3 of 3
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
  4. Installing Motorola Droid RAZR Camera Cover, Battery: step 4, image 1 of 2 Installing Motorola Droid RAZR Camera Cover, Battery: step 4, image 2 of 2
    • Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
  5. Installing Motorola Droid RAZR Camera Cover: step 5, image 1 of 3 Installing Motorola Droid RAZR Camera Cover: step 5, image 2 of 3 Installing Motorola Droid RAZR Camera Cover: step 5, image 3 of 3
    • Remove the two 3.3 mm T5 Torx battery terminal screws.
    • Grab the blue battery removal tab and lift the battery out to remove it.
    • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
    • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
  6. Installing Motorola Droid RAZR Camera Cover, Camera Cover: step 6, image 1 of 2 Installing Motorola Droid RAZR Camera Cover, Camera Cover: step 6, image 2 of 2
    • Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
    • The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
    • Gently pry up the bottom edge of the camera cover with a plastic opening tool.
    • Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
    • Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
  7. Installing Motorola Droid RAZR Camera Cover: step 7, image 1 of 3 Installing Motorola Droid RAZR Camera Cover: step 7, image 2 of 3 Installing Motorola Droid RAZR Camera Cover: step 7, image 3 of 3
    • Insert the plastic opening tool underneath the top edge of the camera cover.
    • Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
    • Remove the camera cover.
David Hodson
150,694 Reputation
127 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 4,746
