Introduction
Before continuing make sure you power down your device and work in a clean area. Also wear a static band to prevent damages to your device.
Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
Unlock the screen's ribbon cable.
To remove the screen, you have to flip the phone over and let it fall out slowly into your hand. Be careful not to put any tension on the ribbon cable.
Then pull the screen away from the ribbon cable connector and it will slide out easily. Do not use excessive force.
