Fix Your Stuff
Right to Repair
Store
Introduction
Before continuing make sure you power down your device and work in a clean area. Also wear a static band to prevent damages to your device.
  1. Remove the back cover using the thumb tab located on the bottom of the phone.
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Remove the battery using the thumb tab. Remove the battery using the thumb tab.
    • Remove the battery using the thumb tab.
  3. Using a T4 Torx driver, remove the eight 4 mm back panel screws. Using a T4 Torx driver, remove the eight 4 mm back panel screws.
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim. It is held together by small clips that lock in. You may have to use extra force to unlock them. Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Gently lift the SD & SIM card board (PCB) as shown. There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
2 other people completed this guide.
Kyle Shays
815 Reputation
4 Guides authored
UMass Dartmouth, Team 1-6, Miles Fall 2015 Member of UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Members
6 Guides authored
One Comment
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
lisa marie - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 233
