Motorola DROID RAZR MAXX Camera Cover Replacement
  1. Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: step 1, image 1 of 2 Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: step 1, image 2 of 2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola DROID RAZR MAXX Camera Cover Replacement: step 2, image 1 of 2 Motorola DROID RAZR MAXX Camera Cover Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola DROID RAZR MAXX Camera Cover Replacement: step 3, image 1 of 3 Motorola DROID RAZR MAXX Camera Cover Replacement: step 3, image 2 of 3 Motorola DROID RAZR MAXX Camera Cover Replacement: step 3, image 3 of 3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola DROID RAZR MAXX Camera Cover Replacement: step 4, image 1 of 1
    • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
    • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
Govind
130 Reputation
1 Guide authored
USF Tampa, Team 14-6, Leahy Fall 2014 Member of USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 Members
10 Guides authored
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 7
All Time: 692
