Introduction
If your Motorola Moto G4 no longer vibrating, replacement of this piece is simple. This guide will show the right steps to replacing a broken vibration motor in the Motorola Moto G4.
Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
Gently pry straight up to disconnect the battery.
Push the battery wires towards the battery to de-route them from the black bracket on the motherboard.
Peel up the black pull tab at the top of the battery, and pull slowly but firmly to separate the battery from the adhesive holding it in place.
If the pull tab breaks, use a spudger or an old credit card to pry up carefully on the edges of the battery until it comes loose.
Pull black flap on bottom of motherboard back.
Use tweezers to pop vibration motor off of motherboard.
