Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Introduction
Go to step 1 ↓This guide shows how to reposition the motherboard in a Game Boy Advance SP so you can access the buttons and speaker.
Slide the power switch to the OFF position and unplug any cables.
If you have a game cartridge in, remove it.
Use a JISÂ 00 screwdriver to loosen the captive screw securing the battery cover.
Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
Four 6.3 mm‑long recessed screws
Two 4.6 mm‑long screws
Use your fingers to lift and remove the power switch cover.
Use your fingers to put the power switch cover (notched side up) into place so the cutout goes around the actual switch.
Gently slide the cover back and forth to make sure it's positioned properly and moving the switch.
Use a JIS 00 screwdriver to remove the three 4.1 mm‑long screws securing the motherboard.
Place a sturdy object such as a stack of books or tool case along the edge of your Game Boy with the hinges.
Use your fingers to gently flip the motherboard over the hinges and prop it up.
