Shop the Holiday Gift Guide
Motex E101 Label Tape Spool Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
57
All Time:
567
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
As you may already know, the Motex E101 is a popular label maker that is commonly used for home and office labeling needs. While the device is durable and reliable, replacing the label tape spool can be a tricky task, if the current spool is not yet empty. However, with the right tricks, you can easily replace the label tape spool of your Motex E101 label maker and continue creating labels without any interruption.
    1. Motex E101 Label Tape Spool Replacement, Unlock the wheel: step 1, image 1 of 2 Motex E101 Label Tape Spool Replacement, Unlock the wheel: step 1, image 2 of 2
      • Press the release button on the back of the device.
      Ask FixBot
    2. Motex E101 Label Tape Spool Replacement, Pull the pin: step 2, image 1 of 2 Motex E101 Label Tape Spool Replacement, Pull the pin: step 2, image 2 of 2
      • Pull the pin securing the wheel.
      Ask FixBot
    3. Motex E101 Label Tape Spool Replacement, Remove the daisy wheel: step 3, image 1 of 2 Motex E101 Label Tape Spool Replacement, Remove the daisy wheel: step 3, image 2 of 2
      • Remove the daisy wheel.
      Ask FixBot
    1. Motex E101 Label Tape Spool Replacement, Remove the old tape: step 4, image 1 of 1
      • Pull the old tape out of the mechanism.
      • You can load the new tape the standard way after reassembling the device.
      Ask FixBot
Author
with
Sebastian
33,910 Reputation
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 57
All Time: 567
