Shop the Holiday Gift Guide
Motex E101 Daisy Wheel Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
52
All Time:
586
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
The daisy wheel is a critical component of this label maker, as it is responsible for creating the raised letters and numbers on your labels. Over time, the daisy wheel may become worn or damaged, which can affect the quality of your labels, or you may simply want to use a different character set to customize your labels. Fortunately, both replacing or just swapping the daisy wheel is a relatively simple process that doesn't even requre any tools. In this guide, we'll walk you through the steps involved in replacing or swapping the daisy wheel on your Motex E101 label maker, so you can get back to creating clear and professional-looking labels in your desired character set.
    1. Motex E101 Daisy Wheel Replacement, Unlock the wheel: step 1, image 1 of 2 Motex E101 Daisy Wheel Replacement, Unlock the wheel: step 1, image 2 of 2
      • Press the release button on the back of the device.
      Ask FixBot
    2. Motex E101 Daisy Wheel Replacement, Pull the pin: step 2, image 1 of 2 Motex E101 Daisy Wheel Replacement, Pull the pin: step 2, image 2 of 2
      • Pull the pin securing the wheel.
      Ask FixBot
    3. Motex E101 Daisy Wheel Replacement, Remove the daisy wheel: step 3, image 1 of 2 Motex E101 Daisy Wheel Replacement, Remove the daisy wheel: step 3, image 2 of 2
      • Remove the daisy wheel.
      Ask FixBot
Author
with
Sebastian
33,901 Reputation
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 52
All Time: 586
