Introduction
In this guide we will be showing one how to replace the forward and backwards buttons to a Modal Rechargeable Wine Opener in 5 quick and easy steps.
Carefully place the spudger under the black cylindrical ring and pry it off the top.
4 Comments
where do you by the replacement switch?
are there any posts for fixing the usb charging port?
If the lights work, the buttons are not the problem. I can get the cork screw to turn manually, but it will not continue run beyond a few tries. Must be the motor.
Could be also the battery. I will try to change the battery.
