Installing Mitsubishi WD57734 Back Panel
  1. Installing Mitsubishi WD57734 Back Panel, Lamp: step 1, image 1 of 1
    • Before disassembling your television, be sure it is powered off and unplugged.
    • Remove the single 18 mm Phillips #1 screw on the lamp access panel.
  2. Installing Mitsubishi WD57734 Back Panel: step 2, image 1 of 1
    • Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
  3. Installing Mitsubishi WD57734 Back Panel: step 3, image 1 of 1
    • Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
    • These two screws are permanently attached to the lamp housing and cannot be removed completely.
  4. Installing Mitsubishi WD57734 Back Panel: step 4, image 1 of 1
    • Using the handle, pull the lamp housing straight back out of the television.
    • Do not touch the glass of the lamp with your bare hands. The oil from your fingers can distort the TV image and lead to other issues.
  5. Installing Mitsubishi WD57734 Back Panel, Back Panel: step 5, image 1 of 2 Installing Mitsubishi WD57734 Back Panel, Back Panel: step 5, image 2 of 2
    • Remove the following 8 Phillips #1 screws:
    • One 22 mm Phillips #1 in the bottom right corner of the back panel.
    • One 18 mm Phillips #1 in the top middle of the back panel.
    • Six 18 mm Phillips #1 in the rest of the back panel.
  6. Installing Mitsubishi WD57734 Back Panel: step 6, image 1 of 1
    • Pull the back panel off of the television by gripping the sides and rotating it down.
Herman Chai
196 Reputation
3 Guides authored
Cal Poly, Team 18-39, Regan Fall 2012 Member of Cal Poly, Team 18-39, Regan Fall 2012
CPSU-REGAN-F12S18G39
4 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 8
All Time: 1,036
