Community-Contributed Guide
Tools
Remove two 7.5 mm #00 screws.
Remove one 9.0 mm #00 screw.
Remove one 13.5 mm #00 screw from inside the battery compartment.
Push the button to pop up the flash.
Remove one 3.5 mm #00 screw.
Remove one 5.5 mm #00 screw.
Carefully lift the top cover away from the body to access wired connections.
Peel back the corner of the rubber grip.
Remove the small plastic cover.
Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
Desolder the red wire.
Carefully lift the sides of the white latch.
Desolder blue, black, brown and green wires.
Remove the loose shim washer if present.
Remove the piece of cellophane tape covering the flex connections.
Desolder flex connetions.
Use isopropyl alcohol to soften the adhesive under the country plate and remove.
Remove one 5mm #00 screw.
Remove one 7.5mm #00 screw.
Remove two 4.5mm #00 screws.
Remove one 5.5mm #00 screw.
Remove the plastic frame around the accessory grip contacts.
Remove one 6.0 mm #00 screw.
Remove two 3.5 mm #00 screws.
Remove one 5.0 mm #00 screw.
Remove the strap lug.
Carefully pull the right panel away from the body. It is still attached.
Desolder the flex connections.
Remove the protective mask around the accessory grip contacts.
Lift the flex contacts free of their retaining posts. Use isopropyl alcohol to soften any glue or tape that is present.
Remove four 4.0 mm #00 screws (standard metric threads).
Remove four 4.0 mm #00 screws (plastic threads).
Desolder the white and pink wires.
Desolder the red, black and gray wires.
Desolder the red, black and orange wires.
Desolder the white and blue wires.
Carefully peal the tape away and detach the red, black, white and blue wires from the glue. Use isopropyl alcohol to soften the glue if necessary.
Desolder the flex connection.
Desolder red, black, gray and orange wires.
Desolder flex contacts.
Disconnect flex connector.
Desolder yellow and purple wires.
Desolder black wire.
Desolder battery contact tab.
Desolder flex connection and remove from retention posts. Use isopropyl alcohol to soften the glue if necessary.
Carefully peal the flex cable from the surface of the flash capacitor. Use isopropyl alcohol to soften the glue if necessary.
Rotate the black gear downward until the mirror flips up into the taking position. It may take several turns.
Remove one 4.0 mm screw.
Gently lift the flex circuit away from the housing.
Remove two 6.5 mm #0 screws.
Remove one 8.0 mm #0 screw.
Remove one 4.0 mm #00 screw.
Remove one 4.5 mm #00 screw.
Remove two 2.5 mm #00 screws.
There may be a shim washer here. Remove if loose.
Remove one 4.0 mm #00 shoulder screw.
Push the mirror box up to free it from the bottom plate.
Lift the left side of the mirror box and rotate it up and out of the camera body.
Check for shim washers at the mount locations. Note location and remove if loose.
