Mio MiVue 698 Disassembly
    1. Mio MiVue 698 Disassembly, Remove screws from the top: step 1, image 1 of 3 Mio MiVue 698 Disassembly, Remove screws from the top: step 1, image 2 of 3 Mio MiVue 698 Disassembly, Remove screws from the top: step 1, image 3 of 3
      • We will disassemble Mio MiVue 698 (Dual) car camera in this guide.
      • On the top of the unit, under the two caps, there are two Philips screws. Remove those caps and use Philips 0 screwdriver.
      Ask FixBot
    2. Mio MiVue 698 Disassembly, Open it up: step 2, image 1 of 3 Mio MiVue 698 Disassembly, Open it up: step 2, image 2 of 3 Mio MiVue 698 Disassembly, Open it up: step 2, image 3 of 3
      • Now use a prying tool and gently pry all four sides of the display assembly.
      • Be careful not to damage the wire strip on the bottom.
      Ask FixBot
    3. Mio MiVue 698 Disassembly, Remove wires: step 3, image 1 of 3 Mio MiVue 698 Disassembly, Remove wires: step 3, image 2 of 3 Mio MiVue 698 Disassembly, Remove wires: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove black adhesive tape from the contacts.
      • Use a plastic tweezers to gently unlock wire strip from the contacts. You will end up with a disconnected display assembly.
      Ask FixBot
    4. Mio MiVue 698 Disassembly, Remove board from the case: step 4, image 1 of 3 Mio MiVue 698 Disassembly, Remove board from the case: step 4, image 2 of 3 Mio MiVue 698 Disassembly, Remove board from the case: step 4, image 3 of 3
      • Disconnect the grey wire, which leads to GPS module.
      • Remove three screws that hold the PCB.
      • Remove the microSD card from the unit. Now you have to use a finger to carefully push against the lens from the front of the car camera, so the board will pop out.
      Ask FixBot
    5. Mio MiVue 698 Disassembly, Remove battery: step 5, image 1 of 2 Mio MiVue 698 Disassembly, Remove battery: step 5, image 2 of 2
      • The battery is attached to the board with a small piece of tape.
      Ask FixBot
    6. Mio MiVue 698 Disassembly, Remove GPS module: step 6, image 1 of 3 Mio MiVue 698 Disassembly, Remove GPS module: step 6, image 2 of 3 Mio MiVue 698 Disassembly, Remove GPS module: step 6, image 3 of 3
      • Remove two screws so you can remove the GPS module.
      Ask FixBot
Peter
163 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 83
All Time: 1,556
