Minolta Dimage Xt Flash Capacitor Replacement
  1. Minolta Dimage Xt Flash Capacitor Replacement, Casing: step 1, image 1 of 3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: step 1, image 2 of 3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: step 1, image 3 of 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Flash Capacitor Replacement: step 2, image 1 of 3 Minolta Dimage Xt Flash Capacitor Replacement: step 2, image 2 of 3 Minolta Dimage Xt Flash Capacitor Replacement: step 2, image 3 of 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: step 3, image 1 of 2 Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: step 3, image 2 of 2
    • Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
Qqq
19 Reputation
1 Guide authored
One Comment
Its a cap not a battery :D
Eigirdas Gedgaudas - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 990
