Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement
  1. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Housing Assembly: step 1, image 1 of 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 2, image 1 of 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Reduction Gear Assembly: step 3, image 1 of 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Reduction Gear Assembly: step 3, image 2 of 2
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 4, image 1 of 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 4, image 2 of 2
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 5, image 1 of 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 5, image 2 of 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 5, image 3 of 3
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 6, image 1 of 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 6, image 2 of 2
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 7, image 1 of 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 7, image 2 of 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 7, image 3 of 3
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 8, image 1 of 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 8, image 2 of 2
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 9, image 1 of 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 9, image 2 of 2
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 10, image 1 of 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 10, image 2 of 2
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 11, image 1 of 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 11, image 2 of 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 11, image 3 of 3
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 12, image 1 of 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 12, image 2 of 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 12, image 3 of 3
    • Now pull the reduction gear assembly up and out of the diaphragm.
  13. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Diaphragm Assembly with Bushing: step 13, image 1 of 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Diaphragm Assembly with Bushing: step 13, image 2 of 2
    • Remove metal piston from the diaphragm assembly.
  14. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 14, image 1 of 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 14, image 2 of 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: step 14, image 3 of 3
    • Using a metal spudger, pull the o-ring off of the assembly.
Payton Parker
534 Reputation
2 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,014
