Introduction
This guide will show you how to replace the diaphragm assembly. A faulty diaphragm assembly can lead to a few different issues including irregular shaking, grinding, or leaking grease.
Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
2 other people completed this guide.
One Comment
to reasemble .
Which is the correct position of the Shift knob assembly ?
