Sodastream Easy adjust crooked bottle holder
    1. Sodastream Easy adjust crooked bottle holder, Rear Cover removal: step 1, image 1 of 1
      • Slide the rear cover backwards and then upwards to remove it from the unit.
      • If you have already installed the CO2 cylinder, you should also remove it and place it upright.
      Ask FixBot
    2. Sodastream Easy adjust crooked bottle holder, Front Cover removal: step 2, image 1 of 1
      • Now you have to remove the front cover. Find the two clips on the open back of the device. They are located at about the same height as the QC sticker, which also contains the serial number of your device.
      • Carefully push one of the clips aside at a time while pulling a bit on the front cover to release it.
      • Then remove the front cover
      Ask FixBot
    3. Sodastream Easy adjust crooked bottle holder, Check Components and align if necessary: step 3, image 1 of 1
      • At the open front side you can now carefully realign the holding mechanism. You will see a white and a black plastic component that should fit into each other. In my case, the pin on the right side has shifted.
      • Carefully lift the white element and push it into the opening.
      • If the white element is in the intended socket on both sides, you have another problem.
      Ask FixBot
Put the front cover back on, put in your CO2-cylinder and put the back cover back on.
You're all set. The problem should no longer occur.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Jens
107 Reputation
1 Guide authored
1 Guide Comment
Gute Anleitung. Bei mir war es aber letztendlich ein anderer Fehler. Ein winzig kleiner Kunststoffspan ragte unten aus der Düse heraus. Da habe ich auf gut Glück versucht den ganzen Zapfen rauszudrehen- andernfalls wäre das Teil eh in der Tonne gelandet. Es hat funktioniert. normales Rechtsgewinde- den Span rausgeklopft- dann war das immerhin schon 9 Jahre alte Gerät wieder in Ordnung. Aber danke für den Tipp mit dem Entfernen der Abdeckung!
Stephan - Reply Share
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 161
All Time: 4,138
