Ridgid GEN5X R8642 Battery Port Replacement
    1. Ridgid GEN5X R8642 Battery Port Replacement, Battery Port: step 1, image 1 of 1
      • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
      Ask FixBot
    2. Ridgid GEN5X R8642 Battery Port Replacement: step 2, image 1 of 1
      • Remove the handle cover by pulling it towards the front of the saw.
      • The grip can sometimes become stuck and may require a decent amount of force to remove.
      Ask FixBot
    3. Ridgid GEN5X R8642 Battery Port Replacement: step 3, image 1 of 3 Ridgid GEN5X R8642 Battery Port Replacement: step 3, image 2 of 3 Ridgid GEN5X R8642 Battery Port Replacement: step 3, image 3 of 3
      • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
      Ask FixBot
    4. Ridgid GEN5X R8642 Battery Port Replacement: step 4, image 1 of 1
      • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
      Ask FixBot
    5. Ridgid GEN5X R8642 Battery Port Replacement: step 5, image 1 of 1
      • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
      Ask FixBot
    6. Ridgid GEN5X R8642 Battery Port Replacement: step 6, image 1 of 1
      • Remove the plastic wire covers to the red and black connections on the switch assembly.
      • When you remove the wire covers, you should be able to see the solder on the wires.
      • Desolder the connections on both the red and black wire using a soldering iron.
      • Once the solder is removed, pull out the wires with the battery port attached to the wires.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 54
All Time: 823
