ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement
  1. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Lower Case: step 1, image 1 of 1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
    Ask FixBot
  2. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: step 2, image 1 of 1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
    Ask FixBot
  3. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
    Ask FixBot
  4. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: step 4, image 1 of 1
    • Use the iFixit opening tool to remove the back of the laptop.
    Ask FixBot
  5. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: step 5, image 1 of 1
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
    Ask FixBot
  6. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Trackpad: step 6, image 1 of 2 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Trackpad: step 6, image 2 of 2
    • Grip the keyboard and carefully pull it off the device.
    Ask FixBot
  7. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: step 7, image 1 of 2 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: step 7, image 2 of 2
    Buy
    • On the back of the keyboard assembly, use the tweezers to pull the white cable from the track pad.
    Ask FixBot
  8. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: step 8, image 1 of 1
    • Remove the three 1 mm screws from the track pad using the JIS 00 screwdriver.
    Ask FixBot
  9. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: step 9, image 1 of 2 ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: step 9, image 2 of 2
    • Grip the track pad with the tweezers and slide it up and out of the keyboard assembly.
    Ask FixBot
Lauren Schirle
205 Reputation
2 Guides authored
Cal Poly, Team S19-G4, White Winter 2019 Member of Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 28
All Time: 576
