Dell Inspiron 15-7547 Hard Drive Replacement
    1. Dell Inspiron 15-7547 Hard Drive Replacement, Bottom Cover: step 1, image 1 of 1
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Close the display and flip the laptop on its back.
      • Loosen the ten 5.0 mm-long Phillips #0 screws.
      • The four screws marked with orange will remain captive to the cover.
      Ask FixBot
    2. Dell Inspiron 15-7547 Hard Drive Replacement: step 2, image 1 of 1
      • Use a spudger to pry up and loosen the back cover.
      • Remove the back cover.
      Ask FixBot
    1. Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
      • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
      Ask FixBot
    2. Dell Inspiron 15-7547 Hard Drive Replacement: step 4, image 1 of 2 Dell Inspiron 15-7547 Hard Drive Replacement: step 4, image 2 of 2
      • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
      Ask FixBot
    3. Dell Inspiron 15-7547 Hard Drive Replacement: step 5, image 1 of 1
      • Lift the hard drive out of the chassis.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 34
All Time: 1,029
