Installing Zune HD Lower Rear Panel
  1. Installing Zune HD Lower Rear Panel, Upper Rear Panel: step 1, image 1 of 1
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Installing Zune HD Lower Rear Panel: step 2, image 1 of 2 Installing Zune HD Lower Rear Panel: step 2, image 2 of 2
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Installing Zune HD Lower Rear Panel, Lower Rear Panel: step 3, image 1 of 2 Installing Zune HD Lower Rear Panel, Lower Rear Panel: step 3, image 2 of 2
    • Insert a small iPod opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
    • Carefully twist the iPod opening tool to pop the lower rear panel off the clips attaching it to the Zune.
    • Repeat this process for the other side of the lower rear panel.
  4. Installing Zune HD Lower Rear Panel: step 4, image 1 of 1
    • Carefully slide the lower rear panel away from the Zune.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 3,141
