Microsoft Surface Pro X Rear Camera Shield Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Microsoft Surface Pro X Rear Camera Shield Replacement, Remove the rear camera shield: step 1, image 1 of 2 Microsoft Surface Pro X Rear Camera Shield Replacement, Remove the rear camera shield: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Insert one tine of a pair of pointed tweezers under one corner of the shield covering the rear camera connector.
      • Lift up the corner to detach it from the frame.
      • If you are going to reuse this shield, try to avoid excessively bending it during removal.
      Ask FixBot
    2. Microsoft Surface Pro X Rear Camera Shield Replacement: step 2, image 1 of 3 Microsoft Surface Pro X Rear Camera Shield Replacement: step 2, image 2 of 3 Microsoft Surface Pro X Rear Camera Shield Replacement: step 2, image 3 of 3
      • Repeat the previous step for the remaining three corners of the shield.
      Ask FixBot
    3. Microsoft Surface Pro X Rear Camera Shield Replacement: step 3, image 1 of 2 Microsoft Surface Pro X Rear Camera Shield Replacement: step 3, image 2 of 2
      • Use a pair of pointed tweezers to lift up the left side of the shield.
      Ask FixBot
    4. Microsoft Surface Pro X Rear Camera Shield Replacement: step 4, image 1 of 2 Microsoft Surface Pro X Rear Camera Shield Replacement: step 4, image 2 of 2
      • Slide one tine of a pair of pointed tweezers under the bottom right edge of the shield to fully detach it from the frame.
      Ask FixBot
    5. Microsoft Surface Pro X Rear Camera Shield Replacement: step 5, image 1 of 1
      • Remove the shield covering the rear camera connector.
      • If the shield isn't completely detached from the frame, pry up additional areas on the edges of the shield.
      Ask FixBot
Kyle Smith
53,242 Reputation
124 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 205
