Microsoft Surface Pro Charging Port Replacement
  1. Microsoft Surface Pro Charging Port Replacement, Charging Port: step 1, image 1 of 2 Microsoft Surface Pro Charging Port Replacement, Charging Port: step 1, image 2 of 2
    • Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
  2. Microsoft Surface Pro Charging Port Replacement: step 2, image 1 of 1
    • Use the plastic opening tool or fingers to pry out the front camera.
  3. Microsoft Surface Pro Charging Port Replacement: step 3, image 1 of 1
    • Lift the outside panel from the Surface Pro
  4. Microsoft Surface Pro Charging Port Replacement: step 4, image 1 of 2 Microsoft Surface Pro Charging Port Replacement: step 4, image 2 of 2
    • Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels
    • Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
  5. Microsoft Surface Pro Charging Port Replacement: step 5, image 1 of 1
    • Pull out left and right metal panels with hands
  6. Microsoft Surface Pro Charging Port Replacement: step 6, image 1 of 1
    • Pull out the orange charging port strip using tweezers
  7. Microsoft Surface Pro Charging Port Replacement: step 7, image 1 of 1
    • Unscrew the two T5 torx screws located on each side of the charging port.
  8. Microsoft Surface Pro Charging Port Replacement: step 8, image 1 of 1
    • Once you have unscrewed the charging port, you can gently pull it out with your hands.
Jonathan Choi
1,005 Reputation
4 Guides authored
Cal Poly, Team 8-20, Regan Fall 2013 Member of Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 Members
16 Guides authored
Past 24 Hours: 14
Past 7 Days: 52
Past 30 Days: 200
All Time: 28,414
