Microsoft Surface Pro 5 Screen Replacement
  1. Microsoft Surface Pro 5 Screen Replacement, Screen: step 1, image 1 of 1
    • Before you begin, discharge the Surface Pro's battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally damaged during the repair.
    • The display is strongly glued to the frame of the device.
    • To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
    • Be careful when using a heat gun, as too much heat can permanently damage the display and/or battery.
    • Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes.
  2. Microsoft Surface Pro 5 Screen Replacement: step 2, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement: step 2, image 2 of 2
    • Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
    • If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display.
    • Insert an opening pick into the gap.
    • Slide the pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
    • Work carefully—the glass is thin and will crack easily if you try to force it.
    • Separate the top edge last. There are antennas on both sides, so be careful not to damage them. Use more heat or a bit of isopropyl alcohol to help weaken the adhesive.
  3. Microsoft Surface Pro 5 Screen Replacement: step 3, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement: step 3, image 2 of 2
    • Pry up the metal shield covering the smaller ribbon cable port using the plastic opening tool.
    • Disconnect the smaller ribbon cable by prying up with the nylon spudger.
  4. Microsoft Surface Pro 5 Screen Replacement: step 4, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement: step 4, image 2 of 2
    • Pry up the metal shield covering the larger ribbon cable port using the plastic opening tool and remove.
    • Disconnect the larger ribbon cable by prying up with the nylon spudger.
  5. Microsoft Surface Pro 5 Screen Replacement: step 5, image 1 of 1
    • Remove the screen from the rest of the device .
Caleb Granch
972 Reputation
2 Guides authored
Cal Poly, Team S15-G3, Livingston Fall 2017 Member of Cal Poly, Team S15-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G3
3 Members
17 Guides authored
Past 24 Hours: 16
Past 7 Days: 138
Past 30 Days: 691
All Time: 47,678
