Microsoft Surface Pro 5 Heat Sink Replacement
  1. Microsoft Surface Pro 5 Heat Sink Replacement, Disconnect the display board: step 1, image 1 of 3 Microsoft Surface Pro 5 Heat Sink Replacement, Disconnect the display board: step 1, image 2 of 3 Microsoft Surface Pro 5 Heat Sink Replacement, Disconnect the display board: step 1, image 3 of 3
    • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
  2. Microsoft Surface Pro 5 Heat Sink Replacement: step 2, image 1 of 3 Microsoft Surface Pro 5 Heat Sink Replacement: step 2, image 2 of 3 Microsoft Surface Pro 5 Heat Sink Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to slide the display cables straight out of their sockets on the display board.
  3. Microsoft Surface Pro 5 Heat Sink Replacement, Remove the display board: step 3, image 1 of 3 Microsoft Surface Pro 5 Heat Sink Replacement, Remove the display board: step 3, image 2 of 3 Microsoft Surface Pro 5 Heat Sink Replacement, Remove the display board: step 3, image 3 of 3
    • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
  4. Microsoft Surface Pro 5 Heat Sink Replacement: step 4, image 1 of 1
    Tesa 61395 Tape
    $5.99
    Buy
    • Remove the display board.
    • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
    • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
  5. Microsoft Surface Pro 5 Heat Sink Replacement: step 5, image 1 of 1
    • Only the screen remains.
  6. Microsoft Surface Pro 5 Heat Sink Replacement, Heat Sink: step 6, image 1 of 1
    • Pry off the protective metal shield covering the main processor using either the nylon spudger or the plastic opening tool.
  7. Microsoft Surface Pro 5 Heat Sink Replacement: step 7, image 1 of 1
    • Remove the four silver Torx T5 x 3mm screws holding the heat sink onto the main processor.
  8. Microsoft Surface Pro 5 Heat Sink Replacement: step 8, image 1 of 2 Microsoft Surface Pro 5 Heat Sink Replacement: step 8, image 2 of 2
    • Remove the remaining five black Torx T4 x 3mm screws holding down the heat sink assembly.
  9. Microsoft Surface Pro 5 Heat Sink Replacement: step 9, image 1 of 1
    • Remove the heat sink from the device by grabbing one of the copper bars with your fingers and lifting straight up.
    • Avoid touching the thermal paste that is on the back of the heat sink and on the front of the CPU. If you get thermal paste on your hands, wash it off with mild soap and water.
Sam Omiotek
73,693 Reputation
288 Guides authored
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 70
All Time: 3,427
