This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
In this guide, I will show you how to perform a replacement battery and screen replacement.
Carefully remove the 2x connector shields with tweezers.
Disconnect the 2x flex cables with a spudger.
Remove the 11 T5 screws from the bezel.
Remove the 2 T5 screws from the rear camera and then remove the rear camera itself. There is one more screw hidden underneath.
Remove the 13 T5 screws from the motherboard.
Remove the 2 T5 screws from the charging port. Remove the plastic cover from the outside and use a pry tool to press the port inward.
Disconnect the cable connectors.
Follow the steps in reverse order to reassemble your device.
