Shop the Holiday Gift Guide
Microsoft Lumia 640 XL Rear Facing Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
44
All Time:
542
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to remove and replace the battery in the Microsoft Lumia 640 XL.
Tools
  • Spudger
    4.9
  • T3 Torx Screwdriver
    4.8
  • E6000 Adhesive Glue
    4.6
  • Tweezers
    1. Microsoft Lumia 640 XL Rear Facing Camera Replacement, Battery: step 1, image 1 of 3 Microsoft Lumia 640 XL Rear Facing Camera Replacement, Battery: step 1, image 2 of 3 Microsoft Lumia 640 XL Rear Facing Camera Replacement, Battery: step 1, image 3 of 3
      • Place left palm on screen and right palm on the back.
      • Press down with fingertips and pull to separate the back from the screen.
      • You may hear cracking and popping.
      Ask FixBot
    2. Microsoft Lumia 640 XL Rear Facing Camera Replacement: step 2, image 1 of 2 Microsoft Lumia 640 XL Rear Facing Camera Replacement: step 2, image 2 of 2
      • Lift the battery away from the phone with the flat side of a spudger.
      • Be careful not to damage the battery.
      Ask FixBot
    1. Microsoft Lumia 640 XL Rear Facing Camera Replacement, Headphone Jack: step 3, image 1 of 3 Microsoft Lumia 640 XL Rear Facing Camera Replacement, Headphone Jack: step 3, image 2 of 3 Microsoft Lumia 640 XL Rear Facing Camera Replacement, Headphone Jack: step 3, image 3 of 3
      • Remove all ten T3, 4.09 mm screws.
      • Lift mid-frame assembly from phone with flat side of a spudger.
      Ask FixBot
    2. Microsoft Lumia 640 XL Rear Facing Camera Replacement: step 4, image 1 of 3 Microsoft Lumia 640 XL Rear Facing Camera Replacement: step 4, image 2 of 3 Microsoft Lumia 640 XL Rear Facing Camera Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Lift and peel connector away from phone using tweezers.
      • To re-attach you may need E6000 Adhesive Glue.
      Ask FixBot
    1. Microsoft Lumia 640 XL Rear Facing Camera Replacement, Motherboard: step 5, image 1 of 2 Microsoft Lumia 640 XL Rear Facing Camera Replacement, Motherboard: step 5, image 2 of 2
      • Remove all three T3, 2.66 mm screws.
      Ask FixBot
    2. Microsoft Lumia 640 XL Rear Facing Camera Replacement: step 6, image 1 of 3 Microsoft Lumia 640 XL Rear Facing Camera Replacement: step 6, image 2 of 3 Microsoft Lumia 640 XL Rear Facing Camera Replacement: step 6, image 3 of 3
      Buy
      • Lift off connector with tweezers.
      • Lift motherboard off with tweezers and pull away with fingers.
      Ask FixBot
    1. Microsoft Lumia 640 XL Rear Facing Camera Replacement, Rear Facing Camera: step 7, image 1 of 1
      Buy
      • Disconnect the rear facing camera from the motherboard with tweezers.
      Ask FixBot
Author
with
Madelyn Kolterman
523 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 44
All Time: 542
