Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement
Video Overview
  1. Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement, Back Cover / Rear Case: step 1, image 1 of 2 Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement, Back Cover / Rear Case: step 1, image 2 of 2
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement: step 2, image 1 of 2 Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement: step 2, image 2 of 2
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement: step 3, image 1 of 3 Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement: step 3, image 2 of 3 Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement: step 3, image 3 of 3
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement, Logic board: step 4, image 1 of 3 Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement, Logic board: step 4, image 2 of 3 Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement, Logic board: step 4, image 3 of 3
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement: step 5, image 1 of 3 Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement: step 5, image 2 of 3 Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement: step 5, image 3 of 3
    • Insert wisdom here.
  6. Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement, Display Assembly - LCD & Touch screen with Frame: step 6, image 1 of 3 Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement, Display Assembly - LCD & Touch screen with Frame: step 6, image 2 of 3 Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement, Display Assembly - LCD & Touch screen with Frame: step 6, image 3 of 3
    • From the old display Assembly we have to move:
    • Earpiece
    • Proximity sensor rubber
    • LCD flex cable Rubber
    • Coaxial Antena Cable
    • Small board with the Charging port and Mic.
  7. Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement, Charging Port Flex - Step One: step 7, image 1 of 1
    • Disconnect the coaxial antenna cable.
    • The cable is attached at several points to the frame and to the board. Gently remove it.
    • The board is glued to the main frame by adhesive tape.
    • Use a hot gun or hair dryer and warm the board.
    • Now you can easy separate the board from the main frame.
    • For the separation process use only plastic tools.
  8. Microsoft Lumia 535 Display Assembly - LCD & Touch screen with Frame Replacement: step 9, image 1 of 1
    • To reassemble your device, follow these instructions in reverse order.
4 other people completed this guide.
ZFix
191,368 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,545 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 1,542
