Microsoft Lumia 435 LCD Display Replacement
Video Overview
  1. Microsoft Lumia 435 LCD Display Replacement, Back Cover: step 1, image 1 of 3 Microsoft Lumia 435 LCD Display Replacement, Back Cover: step 1, image 2 of 3 Microsoft Lumia 435 LCD Display Replacement, Back Cover: step 1, image 3 of 3
    • Switch off the phone.
    • Remove the battery and any inserted SIM and memory cards.
    • Use a screwdriver Torx T6 and remove the 4x black screws.
  2. Microsoft Lumia 435 LCD Display Replacement: step 2, image 1 of 3 Microsoft Lumia 435 LCD Display Replacement: step 2, image 2 of 3 Microsoft Lumia 435 LCD Display Replacement: step 2, image 3 of 3
    • There are several plastic locking clips hold the back cover to the frame.
    • Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
  3. Microsoft Lumia 435 LCD Display Replacement, Logic board: step 3, image 1 of 3 Microsoft Lumia 435 LCD Display Replacement, Logic board: step 3, image 2 of 3 Microsoft Lumia 435 LCD Display Replacement, Logic board: step 3, image 3 of 3
    • Unhook:
    • the touch screen flex cable
    • the LCD Display flex cable
    • Use a plastic tool lift up and remove the Logic board.
  4. Microsoft Lumia 435 LCD Display Replacement: step 4, image 1 of 2 Microsoft Lumia 435 LCD Display Replacement: step 4, image 2 of 2
    • This is the logic board / main board - a front and rear view.
  5. Microsoft Lumia 435 LCD Display Replacement, LCD Display: step 5, image 1 of 3 Microsoft Lumia 435 LCD Display Replacement, LCD Display: step 5, image 2 of 3 Microsoft Lumia 435 LCD Display Replacement, LCD Display: step 5, image 3 of 3
    • The Display metal shield is locked to the frame by 4x locking clips.
    • Use a tool with a sharp tip and careful unlock them and remove the shield.
  6. Microsoft Lumia 435 LCD Display Replacement: step 6, image 1 of 3 Microsoft Lumia 435 LCD Display Replacement: step 6, image 2 of 3 Microsoft Lumia 435 LCD Display Replacement: step 6, image 3 of 3
    • The display is stuck tovthe touch screen glass with a double-sided adhesive tape.
    • Use a hair dryer or hot air gun and worm the glass to make adhesive soften.
    • Distort the frame a little and use a thin plastic tool to separate the display from the frame.
  7. Microsoft Lumia 435 LCD Display Replacement: step 7, image 1 of 1
    • The display is very fragile, do the separation very carefully.
5 other people completed this guide.
ZFix
191,308 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,535 Guides authored
2 Comments
كيف اقوم بفك الهاتف وفحص الخلل الذي يوجد فيه .اعني ان هاتفي لا يقبل العمل اظن انه محروق كيف افحصه ؟
How do I remove the phone and to inspect the defect in which the .ani there is a telephone that does not accept the work I think it's seared how it checked ?
mohammad7salaheddin - Reply
I am pretty sure he didn’t use ifixit stuff to fix the screen, lmao
mario rados - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 3,221
