Introduction
The camera component of the Kinect has three different lenses used for various functions. If you tried cleaning the lens and it didn't fix your problem you should use this guide.
Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
Remove the top portion of the case from the rest of the body.
Detach the side portions of the case from the body.
Remove the fan piece from the side of the body. Unplug it from the logic board to fully remove it.
Remove the front portion of the case containing the lens coverings for the cameras.
The LED component is connected to the front portion of the case. To disconnect it, just pull it out of its plastic connector.
Pull off the microphone panel and snake the cable that was connected to the motherboard through the hole on the camera panel.
Disconnect the bridge connecting the first and second layer of the motherboard.
Pull the first layer of the motherboard off.
Unscrew the three 16.5mm screws using the 5mm Nut Driver.
Unscrew the one 6.5mm T10 Torx screw.
Carefully remove the top body portion of the Kinect from the stand by guiding the cable through the hole on the underside of the body, then lifting the body off of the plastic stand.
Remove the two cameras on the left (which are connected) by pulling their ribbon cables through their respective slots.
Remove the right camera from the metal body by sliding the cable through the hole it lies in.
