Introduction
Follow this guide to replace the main PCB assembly on a Mi-T-M heater model MH-0190-0M10.
Flip the power switch into the OFF position.
Unplug any extension cords from the included power cord.
Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
Disconnect all wires from the main PCB assembly:
The photocell wire connector labeled CN3 on the board
The white wire connector labeled CN2 on the board
The orange wire labeled MOTOR1 on the board
The igniter wire connector labeled CN1 on the board
The yellow wire labeled ACIN1 Yellow on the board
The white wire labeled ACIN2 White on the board
The red wire labeled MOTOR2 Red on the board.
Use a pair of pliers to depress the locking tabs on one of the corner retaining clips securing the PCB to the bracket.
With the locking tabs depressed, pull the PCB away from the bracket to remove the corner.
Repeat for the three remaining retaining clips.
