Metal Backpack Clasp Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
119
All Time:
797
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 7 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
When the clasp on your backpack breaks, you may find that you can't adjust the strap length properly, the strap might even come off completely, or your backpack becomes less functional overall. Luckily, repairing or replacing the clasp is a task you can easily fix yourself. By replacing the clasp, you can extend the life of your backpack and avoid having to purchase a replacement.
Here's a simple guide to help you get your backpack functioning again, as good as new!
    1. Metal Backpack Clasp Replacement, Metal Backpack Clasp: step 1, image 1 of 1
      • Locate the broken metal clasp.
      Ask FixBot
    2. Metal Backpack Clasp Replacement: step 2, image 1 of 1
      • Locate the thread on the strap holding the metal clasp together.
      Ask FixBot
    3. Metal Backpack Clasp Replacement: step 3, image 1 of 3 Metal Backpack Clasp Replacement: step 3, image 2 of 3 Metal Backpack Clasp Replacement: step 3, image 3 of 3
      • Rip the thread using a seam ripper by cutting in a perpendicular direction.
      Ask FixBot
    4. Metal Backpack Clasp Replacement: step 4, image 1 of 3 Metal Backpack Clasp Replacement: step 4, image 2 of 3 Metal Backpack Clasp Replacement: step 4, image 3 of 3
      • Pull out all of the loose thread.
      Ask FixBot
    5. Metal Backpack Clasp Replacement: step 5, image 1 of 3 Metal Backpack Clasp Replacement: step 5, image 2 of 3 Metal Backpack Clasp Replacement: step 5, image 3 of 3
      • Pull out the strap through the buckle.
      Ask FixBot
    6. Metal Backpack Clasp Replacement: step 6, image 1 of 2 Metal Backpack Clasp Replacement: step 6, image 2 of 2
      • Remove the broken metal clasp.
      Ask FixBot
    7. Metal Backpack Clasp Replacement: step 7, image 1 of 2 Metal Backpack Clasp Replacement: step 7, image 2 of 2
      • Hoop in the new metal clasp where the broken clasp was located.
      Ask FixBot
    8. Metal Backpack Clasp Replacement: step 8, image 1 of 2 Metal Backpack Clasp Replacement: step 8, image 2 of 2
      • Fold the strap back through the buckle to match how it was originally.
      Ask FixBot
    9. Metal Backpack Clasp Replacement: step 9, image 1 of 1
      • Grab a needle and thread.
      Ask FixBot
    10. Metal Backpack Clasp Replacement: step 10, image 1 of 2 Metal Backpack Clasp Replacement: step 10, image 2 of 2
      • Mishandling of the needle could result in minor or moderate injury.
      • Re-stitch the strap using a needle and thread following the holes of the original stitch.
      Ask FixBot
    11. Metal Backpack Clasp Replacement: step 11, image 1 of 3 Metal Backpack Clasp Replacement: step 11, image 2 of 3 Metal Backpack Clasp Replacement: step 11, image 3 of 3
      • Tie a secure knot at the end of the stitch.
      Ask FixBot
    12. Metal Backpack Clasp Replacement: step 12, image 1 of 1
      • Cut off any remaining thread.
      Ask FixBot
Finish Line
Joey Wong
208 Reputation
1 Guide authored
UC Davis, Team 1-6, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 1-6, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S1G6
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 119
All Time: 797
