Shop the Holiday Gift Guide
Merch Source Projector Entertainment II Outer Casing Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
All Time:
317
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes - 1 hour
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Merch Source Projector Entertainment II Outer Casing Replacement, Outer Casing: step 1, image 1 of 2 Merch Source Projector Entertainment II Outer Casing Replacement, Outer Casing: step 1, image 2 of 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Ask FixBot
    2. Merch Source Projector Entertainment II Outer Casing Replacement: step 2, image 1 of 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Ask FixBot
    3. Merch Source Projector Entertainment II Outer Casing Replacement: step 3, image 1 of 2 Merch Source Projector Entertainment II Outer Casing Replacement: step 3, image 2 of 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Ask FixBot
Author
with
Winthrop Townsend
287 Reputation
1 Guide authored
Cal Poly, Team 18-3, Maness Winter 2015 Member of Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 317
